Help! Why is my Kodiak leaking gas??
Old Mar 31, 2018 | 09:29 AM
Originally Posted by Noah Mckenzie
I'm having the exact same issue with my old Yamaha three wheeler I replace the whole carburetor Now it only leaks sometimes it is much better than what it was but sometimes it'll still run bad when it starts to run bad it leaks gas out the Overflow the only time it runs bad those occasionally going through mid throttle in a year it'll start toboggan backfire but then it clears up the more i open the air screw the better it is
If you didn't go through that aftermarket carb and made sure it was clean of any debris or machining shavings,has the same jetting as the original carb, that can be a problem in itself.
Old Apr 23, 2018 | 09:03 PM
Nickolas Fuhol's Avatar
Originally Posted by heikoboehm
you will need to take it apart and remove the needle and float to clean it . be careful with the gasket and use a proper size screwdriver to remove the screws of the fuel bowl(so you will not strip the heads).use a small brush and a small pick or flat head screwdriver to carefully remove any derbies and spay with carburetor cleaner ,making sure to spray in all the holes and jets. be sure to clean the outside of the carburetor before you open it.
Try loosening screw on bottom of carb and tightening then adjust to where it just to where it stops leaking .every so often open up and it will drain and loose stuff in bottom of carb bowl and tighten to where it just stops leaking again hope it helps
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
YankeeRebel
Oct 6, 2015 06:44 AM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
