Banshee Clutch Went Out?
Old Mar 24, 2001 | 11:46 PM
War87's Avatar
I had it cranked and in neutral when I was backing it off the trailer. The trailer came up and popped the frame, but not real hard, then all the sudden it was in gear and went dead. I cranked it back up in neutral, but only to find out I had no clutch. I could see it pulling on top of the motor so it wasn't an external problem. Anyway, I eventually cranked it back up in neutral jumped on it a few times and the clutch was working again. I rode it for a good while after that without it acting up. Any clues?
Old Mar 25, 2001 | 12:24 PM
brokemybanshee's Avatar
"I cranked it back up in neutral, but only to find out I had no clutch" how can you tell if your clutch is working if you are in neutral??! I know that banshees and blasters have a wet clutch, so if they are not warmed up the clutch will slip, like if you try to start it in gear when it is cold, it will catch, but if you do it when it is warm it will not.
Old Mar 25, 2001 | 02:07 PM
War87's Avatar
I mean when I held the clutch and put it in first it jerked off and went dead like I wasn't even holding it. Thanks for the info, it wasn't warm at all when I backed it off, that might explain why it ran fine after it warmed up.
Old Mar 25, 2001 | 05:24 PM
I dunno man, mabe it just slipped or something? Kind of weird though... working fine now?
Old Mar 25, 2001 | 09:56 PM
War87's Avatar
It does it from time to time, but nothing serious apparently.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
