Bear Tracker - weird spark issue
Old May 26, 2015 | 09:47 AM
BYC's Avatar
BYC
Pulled the exh.. no go. Using the elec start, I get a spark but with prolonged cranking, the spark gets erratic, then disappears completely. Let it sit, try again, I get spark then slowly goes away.... Grounds and the bar switch are next I guess.. UGHHHHHH
Old May 27, 2015 | 07:51 PM
beyondupnorth's Avatar
I had a moto 4 80 drive me nuts like this. Eventually picked up a adjustable spark gap tester and noticed the spark was always weak. It would push start ok cold, usually start fine once warm but not always. Spark would only jump 1/4" in the gap tester. My XR70 would jump 1/2 to 5/8". I ohmed the coils under the flywheel and the resistance spec was way off. Replaced those and the spark became way stronger and would jump 1/2" gap just fine. Little guy started good after that on the starter and never pushed it again.
Old Oct 19, 2016 | 12:58 PM
Christopher Periphery Olson's Avatar
This is exactly the page i have been looking for! Did anyone find anything out to fix this? I have exactly the same issue as the poster. I am racking my brain trying to get this thing going. i cleaned up every connection in the start path and there was no difference. i have a good ground to everything electrical. coil, regulator, and killswitch have been replaced-all of which have been tested and are in working order.
Old Nov 21, 2017 | 10:52 AM
Jered651's Avatar
I had the same issue on 1 of our 200's I switched the cdi box from my running one to the non and ran like a top It had a brand new mr electric one on it ended up getting an OEM one off ebay runs great now
  #15
Jered651's Avatar
The non running one had week and inconsistent spark
Rigit
Sep 29, 2015 03:02 AM
buckshit
Sep 24, 2015 08:49 PM
traumajunkie
Jun 30, 2015 04:28 AM
traumajunkie
Jun 23, 2015 03:15 AM
traumajunkie
Jun 14, 2015 01:55 PM
