2000 yamaha badger won't turn over
You may have a problem with the neutral light circuit. The starter won't work unless it thinks the bike is in neutral. No idea how complex or otherwise this circuit is on a Badger, you are best getting a wiring diagram to check this circuit. Other possibilities are a blown fuse or bad earth, but could be a faulty ignition switch or broken wire.
Anthony Penney
06-06-2017 08:55 AM
