Polaris66 with yamaha 600 gri issues
Old 12-23-2017, 11:35 AM
polaris66's Avatar
Default Polaris66 with yamaha 600 gri issues
I have this endless green money pit taking up space in my garage. 1ST. Motor blew up approx. 5 years ago had completely redone ran good. 2.nd well kind of being a kid flat tracking around my property and a damn 60 ft. tall 16" pine tree stepped right out in front of me. As you can imagine that didn't end well. New oil cooler modified front brush guard and two teeth and a lot of leg problems which cost more than the quad. But since then new stator was installed new starting solenoid , new battery new brakes. Here is the real issue try to start turns over ok but after you stop trying to start turn off key and kill switch it is still trying to start ???? Before the tree incident the starter would try to engage after it was already running ??? Any ideas what to replace next I did check neutral switch and start button but not sure if it really is start button after reassembly.
Old 12-24-2017, 03:03 AM
If it still tries to turn the starter motor after the ignition switch is turned off, it is the solenoid sticking. However, I have known a dud battery to cause this, so be sure your battery is OK, double check earths and battery leads, and fit another new solenoid.
polaris66
12-26-2017 07:32 AM
greg86hd
11-11-2014 04:27 AM
Gopher500
12-14-2004 12:12 AM
Cowman
05-16-2003 04:57 AM
Quick Reply: Polaris66 with yamaha 600 gri issues
