Gear oil leak 2000 Yamaha Kodiak 400
In the rear gear drive, there is a breather on top. I am leaking fluid out of it. There is no tube on the breather, looks like it broke off at some point. I drained and changed the fluid to see if any water had gotten in there, it had not. The fluid was clean. Any ideas what would cause this or where the breather tube should run.
I'd do as mentioned,running a hose up and making a loop facing downward. This can help keep moisture out and allow the foaming to go back down. This is what the so called experts say on gear foaming that I've read:
Causes
The causes of foaming are many. The most common include:
Water contamination
Solids contamination
Depleted defoamant (possibly due to the use of excessively fine filtration and electrostatic separation technologies)
Mechanical issues (causing excessive aeration of the fluid)
Overfilling of the sump with splash- and bath-lubricated compartments
Cross contamination of the fluid with the wrong lubricant
Contamination of the fluid with grease
Too much defoamant additive, either by incorrect formulation or by incorrect reconstruction (sweetening) of the additive package
Causes
Water contamination
