Warrior won’t start in neutral
Old Mar 11, 2018 | 07:28 PM
JDBOY4450's Avatar
Default Warrior won’t start in neutral
I have it in neutral but it doesn’t register or turnover when I push the start button
Old Mar 12, 2018 | 03:17 AM
If you mean the neutral light isn't working, it also works the start solenoid circuit. So, if the bike doesn't think it is in neutral, the starter solenoid won't work. Check that neutral light circuit. Neutral light also won't work if the battery is flat or main fuse blown, but then nothing else will work either (lights, horn, etc).
Old Mar 12, 2018 | 04:34 PM
JDBOY4450's Avatar
It will register sometimes do you think the neutral safety switch could be bad
Old Mar 13, 2018 | 04:07 AM
Yes, Yams are a bit prone to this, I've got a Kodiak in at the moment (broken UJ) and note that you have to wiggle the gear lever a bit to get neutral to light up. Most switches can be dismantled and the contacts cleaned.
Old Mar 31, 2018 | 09:07 AM
Pete Smith's Avatar
Default Here's how
Pull the clutch in while in neutral and it will start
W4rri0r2000
Sep 24, 2007 07:18 PM
jmoffett
May 21, 2006 12:12 PM
stupidfast
Oct 20, 2004 02:42 PM
