Carb issue
Old Mar 31, 2018 | 09:05 AM
Pete Smith's Avatar
Default Carb issue
So I have a 2003 Yamaha warrior 350 I took the carb apart to clean prior to doing so I could get the wheeler to run but only with the choke fully on so once I cleaned it put it ball on the bike and now it's like I'm getting no gas at all won't start with choke can only get a fire from spraying starting fluid in it any ideas what to do next
Old Mar 31, 2018 | 09:22 AM
Jets were probably stopped up the first time by having to use choke. Second time you had it off could be the needle valve stuck. Once is enough on pulling a carb. Rebuild it and you shouldn't have to go back through it.https://www.ebay.com/itm/YAMAHA-YFM3...VUUom5&vxp=mtr
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Thespazardman
Jun 25, 2002 12:14 AM
johndjmix
Jun 6, 2000 06:46 AM
