2002 grizzly 660 bogging down
Old Sep 23, 2018 | 06:00 AM
Big Rit's Avatar
Default 2002 grizzly 660 bogging down
replaced my entire fuel system including a new carb. starts and idles fine, but as you raise the rpms, it starts to sputter and bog down until it stalls. i'm at a loss as to what my problem could be. any help as appreciated
Old Sep 24, 2018 | 03:18 AM
If your new carb was Chinese it could need cleaning out and will need setting up, may even need different jets. Other possibility a rev limiter coming in early, either due to CDI getting a wrong signal saying you are in reverse, or faulty CDI. This is unlikely to cut the engine altogether though.
One thing to try before anything is a new plug, even if the one that is in was new before the fault started.
Old Sep 24, 2018 | 04:36 AM
Big Rit's Avatar
i just replaced my plug and CDI. if i feather the throttle and get into higher RPM's, when i let off the gas, it will backfire
elishaman79
Jan 3, 2023 07:51 PM
200es
Aug 1, 2018 09:14 AM
KyleW2
May 6, 2017 04:45 PM
Syrupdawg
Feb 9, 2004 12:59 AM
Griz660
Jul 8, 2002 12:38 PM
