Valves and timing
Old Mar 8, 2019 | 09:41 AM
Lestat997's Avatar
Default Valves and timing
we have an old 2000 Yamaha breeze 125 that was blowing oil out the breather so we decided to tear into it and replace the piston and rings. Followed the service manual for it and completed the replacement. Now can’t get it to fire. We have compression, but wants to keep blowing gas into airbox out of carb. I set timing chain at TDC according to flywheel and cam sprocket. When turning motor over with a socket and watching the valves, I have TDC set just before exhaust stroke, is this correct? Or should I do a 180 with it and set to just as intake is opening?
i did adjust valves while at TDC per manual specs. Not sure why I can’t figure this out, need some help here! I do have plenty of spark as well and newer carb.
thanks for any help
Old Mar 9, 2019 | 03:07 AM
The correct TDC is after the inlet has closed and before the exhaust opens ensuring you are turning the engine in it's normal direction of rotation. I usually just put my finger on the plug hole, turn engine by hand, when it tries to blow the finger off watch through the plug hole for the piston rising, and set valves when it is about TDC.
Old Mar 10, 2019 | 06:11 PM
Lestat997's Avatar
Alright thanks I will try again. I can see the timing marks no problem and have verified piston is at TDC through the plug hole as well. I will let you know. Thanks for the reply!
bwiencek
Nov 15, 2023 01:46 AM
Heartnurse73
Oct 5, 2019 12:23 PM
wlvrn
Jul 18, 2013 07:16 AM
prmazdarx7
Sep 27, 2006 11:03 PM
