01 Bear Tracker 250 only runs on Choke
Old Sep 23, 2019 | 04:59 PM
yadzz09's Avatar
Default 01 Bear Tracker 250 only runs on Choke
Hello
So my first problem was it would not stay running with the choke off when it was hot or cold. It was a brand new yahama carb.
The second problem I had was I changed out the carb to an old one just to see whats going on and with that carb I was able to pull the idle screw all the way and it would keep running.
I am thinking on the first carb the pilot jet could be clogged but I m not confused because of the symptoms of the other carb.
I am open to any ideas!!!
Thanks!!!
Old Sep 24, 2019 | 03:32 AM
Not had the problem myself but Yams are noted for air leaks in the inlet manifold. Examine it very closely for cracks.
Old Sep 24, 2019 | 03:36 AM
yadzz09's Avatar
Thanks! I'll check that today and keep you updated
Old Sep 24, 2019 | 11:56 AM
Kymco 450i's Avatar
Yep, those rubber intake boots are known for leaks! Just because the carb is new, does not mean it is adjusted properly or even have the right jets inside...
Old Sep 24, 2019 | 07:18 PM
yadzz09's Avatar
So the intake boot is starting to tear. I didn't look at the simple stuff first the gas was yellow and smelled like rubbing alcohol and than I cleaned the carb to be safe and wouldn't you know it fired right up with no choke needed. It was about 80 here today.
Thanks guys for your help!
Old Oct 13, 2019 | 11:43 AM
DoctorQuad's Avatar
I'm thinking air leak
bigbrew25
Oct 29, 2019 04:10 AM
KSParamedic
Nov 28, 2017 06:03 PM
booger01
Feb 10, 2009 07:33 PM
zerowick
Mar 18, 2006 11:18 AM
djs7795
Dec 18, 2005 10:01 PM
