Reving to the max when started
Old Feb 23, 2021 | 10:02 PM
Bansheeforlife69's Avatar
Default Reving to the max when started
Hey guys I have a 2000 Yamaha banshee 350 twin and I have a problem. When I start my banshee it automatically revs to the max and it bogs we rebuilt the carbs tors delete we have new throttle cable and we did a leak down test and no leaks and we have the KNN air filter drilled into the box should I have the cover on or off. I don’t know what to do please help.
Old Feb 24, 2021 | 08:35 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Make sure the slides are going all the way down. Did you mix them up and put them in the wrong carbs? Throttle cables are not t tight?
They will need to be synced once running.
Old Feb 24, 2021 | 04:01 PM
The slides are in the right one they go all the way up and down cable does not seem tight it’s kinda loose or has slack I would say but before this it was bogging out really bad and could never figure out why but now it just revs to the max
Old Feb 24, 2021 | 04:38 PM
Dazeys's Avatar
Go to BansheeHQ.com those guys know everything there is to know about Banshee's.
Old Feb 25, 2021 | 02:58 AM
In order to rev up a bike needs fuel and air. The most likely place it comes from is through the carb under the bottom of the slide. Only other possibility is an air leak at the manifold, this doesn't give any fuel but if there is excessive fuel about, choke etc, an air leak at the manifold may give enough extra air to give a brief surge of revs before the mix gets too weak to burn.
luisitoelmejor
Feb 10, 2009 08:32 AM
beaty
Mar 2, 2007 07:17 PM
btbell
Feb 25, 2004 02:32 AM
MITTY26
May 25, 2002 09:11 PM
kybanshee01
Apr 22, 2002 11:49 PM
