Electrical problems. I replaced stater clutch and starter
Old Apr 4, 2021 | 10:38 AM
The ferg's Avatar
Default Electrical problems. I replaced stater clutch and starter
Replaced starter clutch and starter, reconnected battery, now theres no pwer to ignition, no lights or power to any functions on handle bars. There is power to starter solenoid and starter. When i test ground from battery to frame my test light come on. New to quads seems like there is a ground issue. Any advise
Old Apr 6, 2021 | 03:03 AM
If there were two leads going to starter, are you sure you connected them the right way round, negative lead to starter mounting bolt, positive lead from solenoid to starter "live" post. Did you connect the battery the right way round? Pos to solenoid. Finally, on most Yams, the solenoid needs to have the thick wires connected correctly M post to starter motor B post to battery.
Old Apr 6, 2021 | 01:03 PM
The ferg's Avatar
There is only one wire to starter, its from starter solenoid. I have the red positive cable and black solenoid starter wire that goes to the front solenoid under front cover connected to positive battery post. The ground wire is connected to the negative battery post. When i check the starter solenoid the fuse on the starter side has no power, i checked the fuse and its good. I have power to starter.
Old Apr 7, 2021 | 03:15 AM
As you don't say what Yam and I'm not familiar enough with them anyway, I don't understand what you mean by "black solenoid starter wire that goes to the front solenoid under front cover" however my point about the solenoid with the fuse on it stands, the solenoid needs to have the thick wires connected correctly, M post to starter motor B post to battery. the solenoid has M and B written on it.
Old Apr 9, 2021 | 08:52 PM
BeanBurrito's Avatar
Check for loose fuses in the areas around the solenoid maybe?
Old Apr 12, 2021 | 09:09 AM
The ferg's Avatar
I found the problem, it was a ground wire issue, replaced the wire from battery to motor and frame. Thank you for the assistance.
Tuffun
Apr 29, 2018 02:34 AM
gdm08
Nov 4, 2012 08:13 AM
4stn4cr
Sep 13, 2008 09:00 PM
nedflanders
Mar 30, 2008 12:16 PM
skratch
Nov 13, 2003 11:32 PM
