1991 Moto4 250 Not Starting
Old Dec 27, 2022 | 01:40 PM
rwynn's Avatar
Default 1991 Moto4 250 Not Starting
My ATV will not start, it just turns over. It was running a month ago. Gas is ethanol free and from this year. and gas is getting from tank to carb. Took spark plug out and checked for spark against exhaust. Sprayed starter fluid in air filter with no luck, then directly into spark plug hole. It acts like no spark but I confirmed spark. Any suggestions welcome.
Old Dec 28, 2022 | 03:07 AM
Check compression and fit a new dry plug. However it is most likely to be a blocked jet, engines need to have an air fuel mix within reason of 14 to 1 so, even with starting fluid, if the ratio is well out, it won't start, Yams are prone to cracked inlet manifolds which weakens the mixture, particularly at cranking speeds, so check that when you take the carb off to clean the jets out.
Old Dec 28, 2022 | 12:18 PM
rwynn's Avatar
Replacing the spark plug did the trick. Thanks for the help.
Mustangboi302
Jun 15, 2012 08:44 PM
kalani808
1) Engine problems..
30
Mar 14, 2012 08:09 PM
Racingbrat
Nov 19, 2011 05:56 PM
OverTheEdge
Oct 27, 2005 10:46 PM
