Swaping a 06 on command front differential to a 02 wolvy
Old Jul 5, 2024 | 09:11 PM
Djayglass's Avatar
Wolverine is a beast
Default Swaping a 06 on command front differential to a 02 wolvy
I have a 02 wolverine that I have tore down and rebuilt with everything off the 06 big bear except the rear end it's still from the wolverine my question is is the big bear front the same gear ratio as the rear or is it going to be dragging the front when u engage it. I am fixing to order axle for it and don't know if I should put the 02 wolverine front end back under it or use the on command
Old Jul 6, 2024 | 03:37 AM
If you have already done the rebuild. Lift all four wheels off the ground. Mark one rear wheel and both front wheels at their lowest points. Out of gear, engage 4WD and turn the rear wheel one full turn by hand, apply parking brake. If it isn't already, set one front wheel to it's lowest point, and check if other front is also at it's lowest, if it isn't, the ratios must be different. If it seems slightly out, repeat turning rear wheels a few more times, any difference will multiply. This assumes same outside dia of tyres on both front and rear, if they are supposed to be different (Honda 300s are) working out ratios, gets a lot more complex.
Old Jul 16, 2024 | 08:25 AM
ColleenMock's Avatar
All good now?
Old Aug 2, 2024 | 09:31 AM
syahux's Avatar
I placed a massive undergo four hundred 2006 front diff in my wolverine 350 1996 alternate the cup of the cv axle to healthy within the endure diff make the wiring and a couple of relay for the servo motor and placed a switch on the dash with a light to peer if he become in 2 or four wheel drive .
Old Aug 3, 2024 | 05:05 PM
aklaki's Avatar
5 Year Member
I went using at mines and meadows this weekend and with approximately 5 miles on my new 30 inch splendid ATV intimidator tires I busted a rear CV and also destroyed the whole front differential. I'm looking at swapping a one thousand differential and just seeing what all I need to try this. I plan on placing rhino axles in all four after the swap additionally.
snaptube vidmate
Old Aug 6, 2024 | 12:45 AM
HowardLowe's Avatar
How is everything going?
redjeepguy
Jun 11, 2007 09:55 PM
todster
Oct 3, 2005 11:24 PM
milld01
Jun 20, 2005 11:26 AM
Blaster96
Jun 18, 2003 01:33 AM
