Anyone rebuild a Warrior shock?
Old 06-19-2001 | 10:23 PM
92LT's Avatar
I'm in the process of attempting to rebuild a stock Yamaha warrior rear shock. I tapped in a valve so it can be recharged. I took it to a local shop, and they filled it with nitrogen. No leaks. I put the shock back on the quad, but it still is all spring, no dampening. So then I took the damper part apart, and put fresh fluid in it. It still doesn't work. Has anyone else done this? Any tips? I just can't figure it out why it doesn't work. The seals aren't leaking.
By the way, warrior rear shocks must not last long. I've owned two warriors, one of which had a blown rear shock. The shock I'm doing now is on my buddies warrior. Used warrior shocks go for around $150 on ebay, and $300 new, so there must be a pretty high demand for them.
Old 06-20-2001 | 12:33 AM
hyper660r's Avatar
92LT It sounds like a bad seal head or some of your shims could be cracked[img]i/expressions/face-icon-small-shocked.gif[/img]
Old 06-20-2001 | 11:52 AM
FISHER1648's Avatar
Check out www.worksperformance.com. I think they offer a "heart transplant" for stock rear shocks. It might give you some ideas ??
Beeline08
11-11-2016 04:00 PM
Barnsnelbon
09-27-2015 03:07 AM
Bernhard
09-25-2015 12:45 PM
cboler9
09-24-2015 08:35 PM
Todd C Wadas
2) Chassis problems..
09-23-2015 11:31 PM
Quick Reply: Anyone rebuild a Warrior shock?
