Please wake up my stock Warrior
if you ask me, nothing is cheap for a quad, but the cheapest thing you can do is add a pipe and k&n filter. It will add a little power, but if you want real power you will have to go with an aftermarket cam and high compression piston....maybe bore the engine out. The cam might be your best bet, alba has a kit with the je piston, .450 lift cam, and titanium reinforced valve springs for 430.00. I would go with that kit if i were you. I want to get it but am a little short on cash. Good Luck.
