BLASTERS AND HILLCLIMBING, DO THEY MIX????????
Old Jul 5, 2001 | 02:07 PM
racefreak's Avatar
Ok yall i might be getting a blaster and we hillclimb alot where i live. How do they do on the long and steep hills? Is it hard to keep the front end down?
Old Jul 5, 2001 | 02:14 PM
scramdaddy400's Avatar
I used to own a blaster and if you don't have momentum your screwed!!!
2000 SCRAMBLER 400 2X4
SCRAMDADDY400
Old Jul 5, 2001 | 02:17 PM
dirt817's Avatar
Where I ride there is a place we call "the steps". It is a series of 3-4 hillclimbs, each is about 70 ft long at about a 60-70 degree incline. I can do them no prob. All I do is lean forward, stand up and put all of youf wieght a little forward, not alot, but enough to keep traction with the front down. I'd say they do fine for a 2 stroke. As long as you stay in the powerband and feather the clutch at the peak you'll be fine.
Blasters do have light front ends compared to your wolverine. You can get used to them real quick.
Old Jul 5, 2001 | 03:55 PM
Dirt817 good point about being on the powerband, that's part of what I was trying to say in my thread.
On my old blaster when I did hillclimbs, I used to go up sand hills at the local construction site. I usually had good luck in third gear pinned but there were a few times when I had to shift into second before I crested the top.
SCRAMDADDY400
Old Jul 6, 2001 | 01:58 AM
Blaster96's Avatar
You can have fun or just make it. My blaster can climb up any hill starting from the bottom in 1st no problem. Or i cn get a run at it at hit it in any gear i want and go straight up. Just do not get really low rear gearing for it.
Old Jul 6, 2001 | 07:14 PM
razormazer's Avatar
My $.02 would be to definitely stay away from a 14 tooth front sproket! I had one on my bike and it was scary trying to make up some steep hills... Keep it in the power-band and you'll do fine Im sure.
Off Subject question : Do yall think that tires make that big of a difference on sand/dirt hills??
Old Jul 8, 2001 | 07:42 PM
Run a 16 tooth front, if anything cut down some teeth on the rear sprocket.
SCRAMDADDY400
Old Jul 8, 2001 | 11:14 PM
kkkiller300ex's Avatar
id have to agree with scramdaddy400 if you lose that momentume tour done i say a few climb some steep hills and it went right up fin but the problume with the blaser is its so short that it wheeles way to much i wouldnt recomend it for the hills its better of in tight trails thats my oppinion.
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
black_thunder
Aug 14, 2015 11:22 PM
