Warrior won't start.....
Old Jul 9, 2001 | 11:17 AM
tuckerabbott's Avatar
I have a 92 warrior and washed it and after, all it would do is make a clicking sound from the solenoid. Could anyone tell me which parts too check for condensation or loose connections and do you think it could be the battery? Thanks again everyone.
Old Jul 9, 2001 | 05:11 PM
sAyIt_fmf's Avatar
SOunds like a loose connection on the battery to me. IF you used a pressure washer...you could have blown some water past the starter seal. There is so much to look at.
I had a 300ex that did the same thing...click..click..nothing..It ended up being a loose connection on the battery...Most likely the negative terminal.
Old Jul 10, 2001 | 01:41 AM
ridnwarrior's Avatar
Like previously said check both battery connections. While you're at it make sure the battery is full of fluid.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Jul 10, 2001 | 12:54 PM
Tooey's Avatar
You could have a loose connection th your battery, your that little white box by the selonoid. Mine screwed up it wouldn't start either. They coast likr $27.00. It is like like a ground, does it even click in when u turn your key on?[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 10, 2001 | 08:42 PM
hey guys thanks!!!! it was the battery terminals being loose. Boy do I feel lame. Thanks again, everyone on here has helped me through all my problems. Any time you have a problem, post it, it works!!!!
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
