Warrior problems Please Help!
Old Oct 17, 2001 | 09:12 PM
dunc_n's Avatar
where can i find this reverse switch wire? what is its function? what will it look like if it is not functioning properly? also, what do you mean by "i just got rid of mine along with the relay."
thanks again
Old Oct 18, 2001 | 12:34 AM
KENTUCKYHILLBILLY's Avatar
the reverse switch plugs into the actuator for your reverse gear. The relay simply has the two wires going into it that kill the starter when it is engaged into reverse. A blue with a white stripe and a red with a white stripe. the relay also has a wire that ground the starter when in reverse thus killing the connection. The last wire is used to actuate the red light up on the handlebars. I took the red and blue wire and cut them behind the relay then wired them together. Thats it. I dont use those silly lights so i just did away with the whole relay. I got a billet clamp that looks alot better and is alot more simple than those lights.
Old Oct 18, 2001 | 01:03 AM
dunc_n's Avatar
I am assuming that when the quad cuts out it is because the relay is shorting the starter to ground. so if this is the problem and I want to keep the indicator lights on the dash what do i need to do?
Old Oct 18, 2001 | 01:19 AM
dunc_n's Avatar
One more thing; I have noticed that sometimes when my quad is in neutral it will not let me start it unless the clutch lever is pulled in. also sometimes when it is in gear it WILL let me start it without pulling the clutch lever in. Is this related to the reverse switch? also sometimes my battery connection comes loose.
thanks again
Old Oct 18, 2001 | 11:37 PM
  #15
If you want to keep those lights you need to leave the wires intact that actuate the lights. That is going to make things more complicated so just remember every wire you cut has a positive or negative aspect. Mostly negative until you do something with that wire. Unless you have a wiring diagram and know what you are doing i wouldnt even try it.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
