Clutch kit
Old Dec 21, 1999 | 06:11 PM
Snapper_Rider's Avatar
Does any company make an aftermarket clutch kit for the Blaster that is better than stock?
Old Dec 21, 1999 | 09:21 PM
thumper4x4's Avatar
I read an article on the Blaster clutch, and it was rated as the best stock clutch for mods. of any quad ever built. Question is what are you looking for?
Springs, disc, more info please...
Old Dec 23, 1999 | 12:18 PM
I am looking for the whole kit. everthing
Old Dec 23, 1999 | 02:08 PM
Mike Frey's Avatar
Barnett is a respected name. They make good clutch kits, plus they sell a heavy duty kit, with stiffer springs. Compared to an OEM or standard Barnett clutch, the heavy duty kit will last longer put the clutch pull will be harder. It is a trade-off.
Old Dec 23, 1999 | 02:36 PM
Would one of the easy pull clutch systems work with the barnett clutch?
Old Dec 23, 1999 | 03:48 PM
sAyIt_fmf's Avatar
Barnett makes a great clutch w/ stiffer springs, but it makes the shifting a bit more notchy until they break in a bit..... All together the kit works great for me.
The easy pull kits will work with the clutch just fine.... Most of the easy pull kits I have seen are attached to the cable itself...so you can make them work with just about any settup. I did not like the idea myself....the one that I was looking into, worked similar to a compound bow...in other words more cables to worry about...other than that....I had some problems with my wrists pumping up on me....But if you ride all the time...the least of your worries will be a tight feeling clutch. you will get used to it. good luck.
Oh yeh by the way.... I have a blaster too....and thats the only clutch that I have yet to replace.
96 Banshee, 97 Blaster, 00 400ex, 93 warrior
Old Dec 23, 1999 | 04:18 PM
Thanks for all the replies. Im gonna go with a Barnett clutch and get an easy pull kit
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
