Shifter Linkage w/MX Boots?
Old Oct 29, 2001 | 03:16 PM
ZRWHAT's Avatar
Just wondering how many of you have had problems with adjusting the shifter for MX boots? I just picked up a set of boots and of course they are still pretty stiff. I adjusted my shifter up quite a bit, but the adjustment screw isn't long enough. I figured that I could throw in a longer adjusting screw or buy a billet shifter lever. Anybody else run into this same problem?
Old Oct 29, 2001 | 04:04 PM
IceMan11's Avatar
Yeah, ran into the same problem. I have a size 13 foot too, which doesn't help things. I went down to the local yamaha shop, and got the shift linkage from a Yamaha Warrior and put that on. It's quite a bit longer. That seemed to do the trick.
Old Oct 29, 2001 | 04:05 PM
BansheeBrad's Avatar
You can always rotate the part that sits on the shift rod. I rotated it clockwise (I think it was clockwise) one tooth position.. gives you alot more up clearence... so much I actaully had to screw the adjustment screw almost all the way in.
It's a 10mm bolt if I remember correctly... takes about 5 minutes
Brad
Old Oct 29, 2001 | 08:34 PM
ZRWHAT's Avatar
Thanks guys. I think I will try to rotate the shifter arm, that will save me $90 on the billet shifter!
Old Oct 30, 2001 | 09:32 PM
RichieRoadRash's Avatar
in an article in dirt wheels or one of those mags they said for raptors to use a warrior linkage if you where boots.
Old Oct 30, 2001 | 10:07 PM
Why pay for a warrior linkage when you can do it for free by just rotating the stock linkage??
Old Oct 31, 2001 | 06:49 PM
don't shoot the messenger.
Old Nov 1, 2001 | 11:58 AM
kuz28's Avatar
The warrior linkage is like $2. or you could go to any hardware store. find the section with bolts and screws...you'll find all diffrent sizes. price? $.30. Rotating the stock linkage will only raise it so far before it starts making contact with the plastic cover for the sprocket. also, if or when you decide to add nerf bars you will need the additional clearance of the warrior linkage. most nerfs mount to the front of the footpeg...robbing you of clearance between the footpeg and the shifter. Good luck.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Steeldon
Sep 9, 2015 09:38 AM
