Douglas .190 Wheels
Old Nov 5, 2001 | 01:25 PM
IronBear's Avatar
PF Powersports LLC
Hello everyone,
I have Douglas wheels .190 on my machine and for some reason, it seems like they bend very easily around the bead. Has anyone else experienced this problem with their wheels? I'm not hitting rocks or anything like that, I just do regular trail and some hill climbing. If you did bend your wheels at the bead, is there a way to fix the wheel? Any information would be greatly appreicated.
Thank you,
IronBear
Old Nov 5, 2001 | 07:36 PM
Blaster96's Avatar
NO to all of the above. You are hitting rocks or something and will end up cracking your rims. I would suggest getting Douglas .90 rims or ITP steel Rims. Very strong and no problems...
Old Nov 5, 2001 | 09:40 PM
Tooey's Avatar
well iahve both i like the douglas better. what kinda tires u have on ur douglas?? sorry to say but itp bend too, my bust off the bead..
Old Nov 6, 2001 | 01:06 AM
VMAX12's Avatar
buy the rims with the rolled edge like the factory one that will help in the strenght
01 BLU660R
Old Nov 6, 2001 | 05:32 AM
Popo35's Avatar
I had the same problem. I bought OMF's with rim rings to protect the edge of the rim.
I have hit some pretty big rocks and no dings so far.
Check out my pic's with rims.
Popo's Fat Raptor
Old Nov 6, 2001 | 12:52 PM
vraptor's Avatar
I have been runing douglas .190 for over a year, and yes I always beat them up on the rocks, my stock rims were getting "square" from the beating. get beadlocks ($$$) if it really bothers you. and yes you can take them off and straighten them out a bit (carefully) with a heavy steel hammer, dont bother though if they are bent so bad they wont hold air
Old Nov 6, 2001 | 01:16 PM
IronBear's Avatar
PF Powersports LLC
Hi VRaptor,
The rims are not bent that bad, just a little. They are not loosing air yet. I would like to correct the problem so that it doesn't get worse.
IronBear
Old Nov 6, 2001 | 01:33 PM
vraptor's Avatar
Ironbear
just take them off put them on a solid (concrete) surface and carefully work the aluminum straight with a hammer, it takes a while, be patient and work it easy and you can get them back to "like new" condition, dont whale (wail?) on them, go easy
Old Nov 6, 2001 | 02:26 PM
redrocker's Avatar
use a dead blow hammer with plastic head
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
