Anyone bypass the reverse rev limiter on 2002 Raptor???
it cant be done to have the reverse light still work but here is the next best thing . trace the wire that is directly behind your shifter it is the wire that plugs in NOT the scewed in wire you need to splice into it somewere . I spliced it and used a small waterproof switch and mounted it on my handle bars . one side is the spliced wire one is to a good ground. then you can turn on and off the rev limmiter.off the light will still work. I just did one for my friend who got a new quad and we installed the switch under the seat so when he let's his kids ride it they have no idea it even can be turned off . this would be the best way to do it for safty resons. good luck and if you need more help e-mail me !!
house1
08-09-2015 10:49 PM
