Blaster seized again. Need advice please.
Old Dec 11, 2001 | 01:43 PM
gaff's Avatar
Piston slapp, did you insure you gave the rings and piston to the one who bored it.
Thiers a type of boring done for type of piston, then the rings are fitted and trimmed if need so.
Old Dec 11, 2001 | 02:12 PM
Quicksand's Avatar
The machine shop I delt with on the original seize supplied the piston, rings, pin, bearing, and gaskets. They've been in business for about 20 years now but it's still possible they screwed up and didn't machine it right.
Old Dec 11, 2001 | 03:01 PM
gaff's Avatar
Things happen, but were on a forum, you can see it we can't, all is just speculation now.
Seal the pipe up and good luck
Old Dec 11, 2001 | 06:01 PM
Quicksand's Avatar
Thanks all for the input on this. I was able to take it to a machine shop and they took a straight edge to the bottom of the cylinder and found out that it was warped just a little. It looked like it was enough for the gasket not to seat on the sides. I thought I'd share the info for any and all that mine run across a situation like this. Again, thanks for the direction here.
Old Dec 11, 2001 | 08:27 PM
  #15
evhwg's Avatar
thats one of the reasons alot of people tell you to do a leak down test. im guilty of doing a top end without a leakdown test,but it isnt a wise decision.
bmxatv10
Oct 14, 2022 06:23 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
bigbear350quad
Sep 11, 2015 12:40 PM
Pahuntman
Sep 5, 2015 11:07 AM
