Anyone had their rear shock blow a seal? (Raptor)
Old 12-11-2001 | 01:27 AM
Paintballer's Avatar
I put the raptor on the trailer after a recent ride. Nothing punishing, I'm too old for that. Just some trail runs, minor jumps (less than 2 feet of air) etc. I'm by no means a great big guy (180 lbs). The raptor is about 3 months old with maybe 15-20 hours of riding on it.
It sat for about 2 weeks after that ride, on the trailer, in weather (if it matters) varying from 40 to 70 degrees.
I went out last weekend to fire it up, unhooked the tie downs and noticed a large puddle on the trailer. My first thought was that I forgot to turn off the gas, but a quick look said this was not the case. A quick inspection revealed the puddle was oil from the shock. It had absolutely NO compression left in it. You could see a couple drops coming from the seal around the rod. It seemed fine when I loaded it last, and nobody had been around it since... Any ideas?
I'm just hoping Yamaha will warranty it
Old 12-11-2001 | 01:41 AM
warrior007's Avatar
You may have had the tie downs pulled down to tight? then with the weather and all...... I havent seen any others rear shock do that, but I can say mine fell apart a few weeks ago.
If it were compressed too far and held there for 2 weeks I could probably see that happening. See if the dealer will cover it. but dont tell them you had it outside and tied down or anything.
Old 12-11-2001 | 01:45 AM
actually, I only had it tied down in the front. My trailer has a big stop on the front of it that pull the quad tight against, so I didn't tied the rear at all. I was only going about 5 miles with it at speeds under 40 mph, so I wasn't too concerned. I dod tie it for long highway trips, but this last ride was local.
Old 12-12-2001 | 04:15 PM
anyone else?
Old 12-12-2001 | 08:44 PM
sonic's Avatar
I'm I correct in saying it's a 2001 machine? Just curious.
Old 12-12-2001 | 08:49 PM
yep, serial number 5999
Old 12-12-2001 | 11:19 PM
NotuRaptor's Avatar
I didn't blow a seal on mine but the compression settings didn't do anything. Yamaha replaced it no questions asked and that was before I even purchased the extended warranty.
/Jon
Old 12-12-2001 | 11:58 PM
660Roost's Avatar
My rear shock leaked the 2nd week I had my Raptor. Same symtoms (puddle on the floor) but in the garage. The dealer replaced the shock at no cost. My serial is 48xx something.
Bratman2
08-06-2022 02:42 AM
07Redrider400
07-25-2015 06:31 PM
Captjay
07-23-2015 01:33 PM
black_thunder
07-22-2015 07:01 PM
cSchwartz
07-09-2015 03:40 PM
