Common Failures of Warrior Engine
Old Feb 17, 2002 | 07:19 PM
budzinsk's Avatar
I have my second Warrior, and it runs great. I have been noticing metal in the oil when I change it, and today, it looks like there is part of a bearing carrier in it (looks like a small I). Is there a common bearing or some other part of the warrior engine/trani's that seem to go wrong? My old one had a stretched timing chain which caused a slapping sound - I believe that is a common problem - but this one does not have that. Any ideas???? I would like to hear of problems other peopl have had.
Thanks
Old Feb 17, 2002 | 08:09 PM
54warrior's Avatar
I have a 96 Warrior. And if I were to estimate, I have app. 1500 hrs on this machine. It has never given me a lick of trouble, when I bought it new in 96, the dealer told me to keep the filter clean and the oil changed. It's worked very well, and has been a reliable quad. I will say, however, that I've replaced every bushing/bearing on this machined, except front wheel bearings. I have adjusted the valves once. This has been a very reliable machine. I have noticed, like you, that there has been some metal shavings in my oil when changed, but have never seen or heard of any common bearings going out. Sorry I can't be of much help, but just thought I would tell you my experience.
Old Feb 17, 2002 | 10:32 PM
yamahagye's Avatar
If you warrior is brand new, the metal shaving's could just be from the engine breaking itself in. The internal parts come too close together from the factory, so they wear down and leave metal flakes. If the problem does not go away after a month, something more serious may be going on inside your engine.
JaMeS
Old Feb 18, 2002 | 04:06 PM
budzinsk's Avatar
Thanks for the replys. It is a 1990 model, and the metal seems to be larger than shavings. The engine runs great, no noise, just some metal (steel - I used a magnet) shavings. Like I said, the one looks like a little I - which must be from a bearing. I guess I will keep driving it until I hear something.
Thanks,
Rob
Old Feb 18, 2002 | 09:09 PM
A2000's Avatar
My mechanic told me that this is common in Warriors of all years. I've noticed it on mine too. I wouldn't worry....the filter grabs all of that crap anyway.
Reactant
Mar 30, 2022 02:08 AM
manuelrivera
Aug 8, 2015 04:34 PM
Ashley S
Jul 31, 2015 09:46 AM
Reactant
Jul 27, 2015 07:45 PM
Reactant
Jul 16, 2015 10:29 PM
