BeAt ReD HeaDerS
Old Feb 23, 2002 | 12:49 AM
yfm660r's Avatar
Stage 2 Kit, 148 150 mains, 4th clip on needles, air/mixture screw 3 turns out, cut snorkles, back 2/3rds of air box lid cut off, biggun full exhaust. Plugs are always lean, but that doesn't neccasarily mean anything. I've had it for about 8 9 months and have never adjusted the valves untill now, i got everything back together and test drove it and it runs way better than it ever has before, the thing is, my headers get red hot now, i noticed it when i left it runnin to go in the house for a few minutes, whats this mean ?
Old Feb 23, 2002 | 08:17 AM
Ward660R's Avatar
Mine does the same thing.I used to think it was lean so I put in 27.5 pilots that helped alot. It still does it but not as bad. I have been running it this way for almost a year so I can't hurt it that bad. You may want to check and see if it does it while riding, mine didn't.
Old Feb 25, 2002 | 12:44 PM
CBUS660R's Avatar
You need the bigger pilots. When you let it idle, thats the carb circuit that you are running on. With the airbox mods, you are now flowing more air than the stock pilots are designed for.
Old Feb 25, 2002 | 01:10 PM
vraptor's Avatar
this is a sign of an idle lean condition, so long as it is only the idle circuit you should be ok, you can turn your airfuel mix screw out 1/2 turn to richen it up a bit if you want to correct it, pilots dont come into play until you roll on the throttle (usually 1/8-1/4 throttle)
95wolv
Sep 27, 2024 12:00 PM
Minimod
Sep 10, 2015 08:03 AM
Bigtwin700
Sep 9, 2015 09:32 AM
toonces
Aug 13, 2015 12:40 PM
