98blaster setting clutch
Old Apr 22, 2002 | 12:49 PM
pooh28's Avatar
rebuilt the engine last night, but need help setting clutch springs and adjustment
Old Apr 22, 2002 | 02:23 PM
KNOWSALOT's Avatar
The Facility
There is no adjustment other than your cable adjustment.
Did you have this apart when you tore down your engine??
Do you have it together and now your clutch will not release??
Old Apr 22, 2002 | 02:27 PM
pooh28's Avatar
yes, I had the motor torn down for a rebuild, and now its together, but the clutch had to come apart to get the crankcase apart. now I'm stuck on the spring loaded bolts on the clutch pads.
Old Apr 22, 2002 | 06:52 PM
KNOWSALOT's Avatar
The Facility
Well, you tighten your springs down to whatever torque the manual specifies. You tighten them all the way down.
As far as the order of plates, you start with a friction plate first against the clutch basket. Then a steel, then a fiber,then a steel,etc,etc........If it's done correctly, you should end up with a friction plate against the pressure plate.
Also, don't forget the "BB" ball on the clutch push rod when re-assembling your parts. Way too often, people lose this and forget it. Without it, your clutch will not completely dis-engage when you pull the lever and all the cable adjustment in the world isn't going to help.
ghost civic
Jan 15, 2020 07:43 AM
4464
Aug 21, 2015 01:46 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
