Raptor carb/ choke
Old Apr 23, 2002 | 07:25 PM
rraptorr13's Avatar
Has anyone had a problem with there choke cable loosening up on the carb? Any other problems with the choke set up ?
Old Apr 23, 2002 | 07:33 PM
THEMOOSE's Avatar
I heard crud can get in the choke & make it stick & the spring can break.
Old Apr 24, 2002 | 06:01 PM
ZRWHAT's Avatar
If you power wash your raptor and ride in the mud regularly you will have problems with your choke sticking sooner or later. What happens is that your powerwasher shoots dirt down the inside of the cable and into the carb where the choke plunger resides. I found mine the hard way when all that water and mud froze and locked up my choke. Not a problem starting, but the spring wasn't strong enough to overcome the ice and mud. This means that you are always on choke, which means you won't get anywhere fast.
Old Apr 24, 2002 | 06:09 PM
velocityraptor's Avatar
<< If you power wash your raptor and ride in the mud regularly you will have problems with your choke sticking sooner or later. What happens is that your powerwasher shoots dirt down the inside of the cable and into the carb where the choke plunger resides. I found mine the hard way when all that water and mud froze and locked up my choke. Not a problem starting, but the spring wasn't strong enough to overcome the ice and mud. This means that you are always on choke, which means you won't get anywhere fast. >>
There it is! been there done that.
Old Apr 24, 2002 | 09:10 PM
rraptorr13's Avatar
Checked it. Cleaned it. Fixed it. Thanks guys.
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
black_thunder
Sep 22, 2015 07:59 PM
