Question about piston life of blaster
Old Sep 29, 2002 | 05:35 PM
  #21
hardlydangerous's Avatar
<< anybody sell an oil injector rebuild kit???? >>
I agree just remove it .... BUT just do it your self! It costs nothing an no parts need to be made ,no need to even buy a kit.
Simply remover the clutch cover remover the clip that holds on the plastic oil pump gear. and remover the gear. Then put the cover back on.
Now just block off the oil inlet on the carb with either a vacuum hose plug ( availible at any automotive store) or som jb weld or epoxy.
thats it, if you do it this way ( removing pump drive gear so it wont work)and do not remove the pump from the cover then you don't need to buy a kit, and now you can remover all the lines and tank.
Bergmann
Aug 13, 2015 03:51 PM
toonces
Aug 13, 2015 12:40 PM
315blaster
Aug 8, 2015 08:13 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
