02 Grizz Grease zerks?
There are 6 total, 4 are easy, 2 are a painintheass.
There are 2 each on the rear hubs....just remove the tires and you will see them looking at you.
There are 2 more on the front drive shaft universal joints....they are hard to get to. You need to get them in the right position, and you "should" be able to get the grease gun onto them. If not, try using a needle adapter.
Good Luck,
Steve
Good Luck,
Steve
