Needle clip position
Old Sep 26, 2002 | 08:39 AM
Murph660R's Avatar
I forget this every time. Example: When you say 4th clip position on your carb needle do you count from the top or the bottom?
Old Sep 26, 2002 | 09:02 AM
garyc660R's Avatar
From top.
Old Sep 26, 2002 | 11:45 AM
eRAPTOID's Avatar
Hey G,
Will lowering the needle lean out the entire circuit? or just the lower to mid half?? Thanks!
Old Sep 26, 2002 | 12:06 PM
Murph660R's Avatar
I might not know the reference point for clip position but I do know that moving it will only affect your F/A ratio at 1/8 to 3/4 throttle. Thanks Gary.
Old Sep 26, 2002 | 12:19 PM
eRAPTOID's Avatar
Thanks Murph! I'm okay on full throttle, but believe I am slightly rich on everything in-between, especially lower 3rd! I believe I'm gonna drop them one and see. I am currently on the 4th position from the top, I will go to the 3rd and hope for the best.
"TOID"
Old Sep 26, 2002 | 12:37 PM
garyc660R's Avatar
Toid, what jetting did you wind up with?
Old Sep 26, 2002 | 12:46 PM
eRAPTOID's Avatar
Remembering that it is all Dyno Jet components, I am at 150/155 in the 4th position.
But would like to lean out the lower 3rd of the circuit a little. Thus wanting to drop the needles a hair. What do you think? The plug seems perfect at full throttle.
Old Sep 26, 2002 | 02:56 PM
Murph660R's Avatar
Sounds like that is exactly what you need to do.
Old Sep 26, 2002 | 03:07 PM
eRAPTOID's Avatar
Thanks again.[img]i/expressions/face-icon-small-wink.gif[/img]
Does anyone else out there happen to be on the 5th clip position from the top?? Or would I be a loner?!
Old Sep 26, 2002 | 04:13 PM
BlueLeader's Avatar
I had an e-series with 16 discs, dynojet 148/150, needle clip in 3rd slot from top, K&N filter...ran great!!
