Pics of Dyna CDI box for raptor??
Anfused- thanks for the pic. I talked to scott the other day at dyna. If i heard correctly (cell phones) that yamaha raptors ignition is somehow different than most others, hence the delay in the box. They have to overcome some problems. I think jon, Raptor720 has tested a box for Harry at Trinity. Harry and dyna are the only known guinea pigs at this point. I was just wondering what it looked like installed in the raptor. Same Size, easy to adjust etc. Any installed pics?????
I am about to decide it is not worth it. Built right you do not need. I feel it is mainly for the alky guys anyway. I am starting to break parts left and right. I know that it is put together right cause Bob is like a surgeon.[img]i/expressions/face-icon-small-smile.gif[/img] We beef up everything as we go. I am afraid to switch to alky for not knowing what will go next. It is pretty dam fast on race gas now. This subject has kinda of died after raptor720 talked a little about it 3 months ago. Others claim to have them on there raptors but everybody at dyna tells a different story. I doubt that it is a top secret thing because dyna would like to sell them if they have them or are building them. Anyway i am finally happy where i am at. Catch me if you can, if you do my hat is off to you.
Guys, if the dyna for the raptor is anything like their banshee ignition, it is worth buying. However, if you can wait a couple of months, wait until their dealers get them. From dyna the banshee ignition is $380. I ordered mine from pro-flo for $280. If you haven't read my previous posts (search for "my review of the banshee dyna ignition), this ignition is awesome. The customer service is great also. I am trying to find the time to install the box on my TT bike and line it out. I had my first one on there and went from a 330 main jet with stock box, to a 400 main with the dyna, and the ignition was acting up. On the pump gas piped play bike, I went from a 270 to a 330.
I am sure the raptor igntion will be just like their others. There is a pigtail with a small box with 2-2 postion dip switches. To change from one timing curve to another, simply put the switches in different postitions. I haven't got my programming kit yet, but when I do I can use a PC to map out any timing curve I want. This will be great because you can map it to your powerband. They can install throttle postion dependant circuits. At certain throttle positions, the box can revert to a different timing curve. Also, they can add another circuit that will change your timing curve when electricity is sent through it. Such as when N2O is activated.
All the dyna igntions plug directly in and bolt to the stock mounting positions. The banshee box is quite a bit smaller than the stock one, so dyna supplies a good quality mounting bracket with rubber padding.
I am impressed with mine and will soon order another so I don't have to keep swapping it between bikes. My friends MSD can't compare.
