Warrior Problem.
Old Oct 28, 2002 | 01:17 AM
FORDHATER's Avatar
Default Warrior Problem.
Hello. My dad has a 2001 warrior. He just installed a pro circuit pipe on it and the pro design filter system with a foam filter. My sister had it at dumont all weekend and said it ran fine. But today when we got it back it runs fine if you gradually rev it up but if you let the idle slow down and then press the thumb throttle all the way in it dies and acts like it either gets too much gas and floods or not enough gas. Does anyone know why it would do this? I would appreciate any information. My dad has had a few problems with it and says if it wont run good this coming weekend at dumont he will sell it. Thanks.
Old Oct 28, 2002 | 01:44 AM
Blastermaster's Avatar
if you did all those mods with out changing your jetting it is way lean cause i know my pro design filter system with a foam filter leand my raptor out
Old Oct 28, 2002 | 02:00 AM
FORDHATER's Avatar
Yes we got it re jetted but im not sure what they are. It was done at a local shop. Normally the guy does an excellent job, so i dont think it has to do with jetting. It could though.
Old Oct 28, 2002 | 03:04 AM
maybe junk in the carb
Old Oct 28, 2002 | 08:00 AM
VirginRider's Avatar
make sure your emergency break is not engaged at all, and then try a new plug if all else fails gota be carb. related!
Old Nov 6, 2002 | 09:21 PM
Warrior350CR's Avatar
Fordhater,
You are most likely running lean. I have a 2002 warrior and just put a supertrapp IDS2 exhust and twin air filterand modified air box lid. Iwent from the original #145 main jet to a #152.5 and 3 turns out on the air/fuel mixture screw. It runs great !! It was a bit rich until I modified the air box lid. I would start with the #152.5 main and 3 turns out on A/F screw and see how she runs.
P.S. I know you hate Fords, but the 5.0s kicked some *** !!
Old Nov 6, 2002 | 10:28 PM
JakalWarrior's Avatar
Simple solution. Cover up half your filter and see if it gets better or worse. If that dosent tell enough try it without one for a second (not riding, just revving). This should tell you if your lean or rich.
Beeline08
Nov 11, 2016 04:00 PM
shimanok2
Jan 29, 2016 07:37 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
