Raptor cam install help
Old 11-23-2002, 08:56 PM
Ward660R's Avatar
Default Raptor cam install help
I am having a little trouble with the cam install, finding the center line in paticular. Is there a way to use a dial indicator with out the cam cover on it? Is comming off of the rocker armgoing to affect the center line?
PLEASE HELP!!!
Old 11-23-2002, 09:08 PM
RaptorRcR's Avatar
Ward...is the motor at TDC? If so...the cam sprocket has 3 dots on it. The dot in the middle should be on top..and the 2 side dots should be level with the head. The motor is angled..so level the dots with the motor..not level to the ground. Once you have your cam sprocket in...the cam has 2 holes in it on the intake lobes. You need to line those up with the dot in the middle of the cam sprocket.
Now look at your cam lobes..the exhaust lobes should be towards the front of the motor..and the intakes towards the rear. If you have any questions..post back or reach me on AIM sn = Pullinwool
Old 11-23-2002, 09:29 PM
Ward660R's Avatar
What about the 0.010 taken off the head? The cam won't line up like that anymore, right?
Old 11-23-2002, 09:31 PM
RaptorRcR's Avatar
Ward..yes, it will. Try and be clearer on your problem and explain all of the details..I seem to be missing something. The head being shaved .010 shouldnt affect this at all.
Old 11-23-2002, 09:42 PM
Ward660R's Avatar
I sent you a PM before I typed the new topic btu guess what I got my R's and C's mixed up. I only half know what I am talking about so this might be a little complex, I am typing for another guy so I don't really understand. We were trying to find the center line using a dial indicator on the rocker arm since we can't go off of the cam. Will this effect the center line? Is there a way to hold the cam in without the cam cover? With the head being shaved it doesn't effect cam timing?
Old 11-23-2002, 09:45 PM
RaptorRcR's Avatar
Ward...give me a call. Check your pms.
Old 11-23-2002, 09:47 PM
Ward660R's Avatar
You DA man.
Old 11-23-2002, 10:05 PM
RaptorRcR's Avatar
Post back when you get it together!
Old 11-23-2002, 10:52 PM
RaptorRcR's Avatar
Ward...did you get one of the new cams? The stage 2 cams we run right now had a problem with the decompressor hole being too deep and hotcams made a new pin for us. If your cam says HHT on the sprocket side...do not run your stock pin. It will chew it up. Bob and I chewed up our stock pins pretty badly. They look like drill bits they are so sharp. If you do have one of the HHT cams, call hotcams on Monday and talk to Sean. He will get you a pin that works with the cam. I tried calling you back before you bolted it all together..but the line was busy. Let me know how it goes and what you ended up doing.
Old 11-24-2002, 03:28 PM
Ward660R's Avatar
Thanks for trying to call, wshrdskin already helped me out on that one. I have a DHT. I am on my way to put it in. Thanks for your help!!!!!![img]i/expressions/face-icon-small-smile.gif[/img]
BTW I tried to call 14min, wrong #, opps.
Quick Reply: Raptor cam install help
