Problems with my Warrior
Old Dec 24, 2002 | 01:22 PM
oddmetal's Avatar
Default Problems with my Warrior
I have a 2000 Warrior and the other day i went to start it up, put the gas flow on and gas came pouring out the overflow hose underneath the carbuerator. It's cold out now and some people thought some valve in the carb might be sticking. It will run with the gas on off but will die out like it ran out of gas.
If anybody has any ideas let me know...thanks
Old Dec 24, 2002 | 02:11 PM
JakalWarrior's Avatar
check to see if your float is stuck, bent, frozen or something. In other words, open up and, play with the float valve while spraying some carb and choke cleaner at it.
Old Dec 24, 2002 | 02:33 PM
warrior86's Avatar
that happened to me two weekends ago when i was riding in twenty degree weather. Tried smackin the carb but wouldnt do anyting i just let it sit. IT just fixed itself. Hopefully u will be that lucky. happy holidays/ warrior
Old Dec 24, 2002 | 02:37 PM
llknowlesll's Avatar
I had the same problem on a banshee that i owned before. It was the float sticking. I just tapped the bowl with a hammer and it worked fine. It did that during the winter.
llknowlesll
Old Dec 24, 2002 | 03:27 PM
oddmetal's Avatar
OK thanks for the help i'll just wait and see if it fixes itself. Thanks for all the help.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
