rims???
Old Jan 11, 2003 | 12:02 AM
miniblaster's Avatar
Default rims???
I have stock tires and rims on my shee. the rim is a 9 inch rim, i think a 10 would look better, will everything fit right if i get the 10 inch instead of the 9 inch? thx
mini
Old Jan 11, 2003 | 12:32 AM
Default rims???
someone, plz help me?
Old Jan 11, 2003 | 12:49 AM
Blaster96's Avatar
Default rims???
You will need to make sure it has the same lug pattern and the new tire you will get needs to be the tright size. otherwise it is ok.
Old Jan 11, 2003 | 01:03 AM
Default rims???
well i'm buying a wheel and tire combo, so it will definately fit, and its made for the shee so i'm guessing it will work. thx for your help
Old Jan 11, 2003 | 02:03 AM
desracers's Avatar
Default rims???
When you order the tire with rim, order thur Rocky mountain ATV. They will give you what you want....as long it fit for your bike....
Old Jan 11, 2003 | 10:44 AM
660bigdaddy's Avatar
Default rims???
let me know if you want to sell your stockers. the only problem w/ 10" rims in the back is less side wall and you take more of a chance in bending a rim.big daddy racing
Old Jan 11, 2003 | 11:22 AM
AlkyBurninX's Avatar
Default rims???
I like running 10" on front and back. You have a better tire choice with 10" rears. Some heights, widths, and tread aren't offered for 9". Your bolt pattern is 115mm rear and 156mm front.
Old Jan 11, 2003 | 02:59 PM
Denver660R's Avatar
Default rims???
The smaller the rim size the softer your ride will be. The larger the rim the harder the ride. More tire= more impact obsorption. I ride with 8" on the rear and 10" on the front and i love the way it corners and handles big air. This is with Itp mx's all around. 19" fronts and 18" rears.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
fd24
Jan 16, 2019 08:59 AM
PinkFloydEffect
Sep 25, 2015 06:31 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
