Is there a Factory or Aftermarket Solution to Griz Overheating?
Old Apr 13, 2000 | 01:29 AM
mbrown's Avatar
I've read of some folks insulating the fuel lines and tank to prevent vapor loc and adding little computer cooling fans to cool the motor a bit more, and adding bigger main cooling fan . . . but is there a more difinitive factory or aftermarket fix for this problem? I REALLY want a Grizzly but the kind of slow moving hard use on hot days is exactly the kind of use it will get. I don't want to end up ruining the motor in a few years. I'd rather spend a few bucks on a nice oil cooling system or better fan set up or something. At the other extreme, how's it do in the extreme cold? When I want to plow the snow off the drive first thing in the morning, will the Griz oblige?
Lastly, I realize a big motor uses more fuel. How far/long can one expect to ride on a tank?
Thanks a ton,
Matt.
Old Apr 13, 2000 | 09:55 PM
MonsterGrizzly's Avatar
The Griz can be fixed where there is very little heat coming from the motor. But in stock form it does its job great except for very hi temps. Its really not as bad as every one puts it out to be. In the winter, we have temps as low as about 10 15 degrees. The Griz with the chock applied will crank up every time and warm up very quickly. I usually us the half choke. Fuel wise the Griz has a big gas tank (5.1 Gallons) that allows it to go great distances. Usually 80 to 90 miles on my tank. It does have a big motor and does suck gas but not very bad. Its a great machine and I recomend it to any body that can handle a MONSTER.
Old Apr 13, 2000 | 09:58 PM
Old Apr 13, 2000 | 10:40 PM
mbrown's Avatar
MonsterGrizzly, hoped you'd reply. You say I can fix it so that the engine heat isn't a problem . . . so what are your two top engine heat reducing tips? I've decided to buy the Grizzly and want to nip this problem in the bud at the start. Also, I notice you're gonna put in a 730cc bore kit . . . sounds Monstrous!! What's it cost/invovle mechanically? Pointless to do it without other mods? Thanks for your tips on the overheating issue. M.
Old Apr 14, 2000 | 09:37 PM
Stupid computer posted my post 2 or 3 times. Well the two unexpensive things you can do to the Girz is buy a bigger fan and allow the fan to be turned on automaticly by installing a switch. It shouldn't cost to much for the switch but for the bigger fan it can be bought for about $50-100. But it WILL allow your griz to run alot cooler. There are many other things you can do but if you want to know about them let me know. Right now the 730cc is new. So I can't find no information about how much it is. When I find out though it will probably clean out my wallet. With it on, adding more mods will make it even more badder than what it is. So if you want even more power you could install even more things. Any more info about these mods or about other cooling methods. Halla at me.
Old Apr 14, 2000 | 09:38 PM
Stupid computer posted my post 2 or 3 times. Well the two unexpensive things you can do to the Griz is buy a bigger fan and allow the fan to be turned on automaticly by installing a switch. It shouldn't cost to much for the switch but for the bigger fan it can be bought for about $50-100. But it WILL allow your griz to run alot cooler. There are many other things you can do, but if you want to know about them let me know. Right now the 730cc is new. So I can't find no information about how much it is. When I find out though it will probably clean out my wallet. With it on, adding more mods will make it even more badder than what it is. So if you want even more power you could install even more things. Any more info about these mods or about other cooling methods. Halla at me.
Old Apr 14, 2000 | 09:42 PM
Old Apr 15, 2000 | 05:49 PM
grizzzzzz's Avatar
all i want to know is where to buy the fan. and what else you have done for this problem. my 99 grizzly will start at 25 below every time but it runs cold blooded for a few minute's.
thank's todd
Old Apr 16, 2000 | 08:08 PM
Jaime's Avatar
Well i kinda slipped over here from the polaris site just snoppin around but i can answer your question on the fan. Get ahold of Hank Gossnel at Gosnell Atv in Idaho he has the fan kits and clutch kits he will fix you up LoL Jaime
dannytas
Sep 26, 2017 06:31 PM
EIF
Apr 20, 2017 07:15 PM
cboler9
Sep 24, 2015 08:35 PM
Ask the Editor
Sep 14, 2015 08:57 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
