problems getting bigbear from reverse to neutrual or 1st
got an 03 bigbear4004x4 still under warranty but was just wondering if anyones noticed a problem with shifting from reverse to neutrual or 1st not all the time but i tryed like 4 or 5 times and had to evently get it by using my hand to pull up on it a couple of times?? anyone else havin this problem and if so if you had it fixed what caused it??
I had a bolt come out on my Kodiak shifter once that caused me some problems that sound similar. I had to removed the rubber boot and several bolts to get it apart enough to retrieve the bolt that came out. Luckily, I didn't loose it.
The other thing that makes it hard to change gears is if your idle is set too fast.
/NotuRaptor
/NotuRaptor
ya i got a 2003 big bear and have that same exact problem, no one but me can do it with my foot [img]i/expressions/face-icon-small-smile.gif[/img] you just gotta give it a good shake while trying to push up on the shifter at the same time and it usally works...wierd? lol the bear is a hard shifter thought but im used to it my last machine was a 84 honda 200s atc which had a horrible tranny and shifted SO BAD so the bear is like god to me [img]i/expressions/face-icon-small-smile.gif[/img]
i have an 05 bigbear and coming from a raptor which i used to own it was a whole different feeling when i was trying to shift gears. sometimes if u give a good wiggle when ur shifting while stopped it helps.
I've had the same troubles. I've had some success holding in the left hand brake lever, and sort of rocking. No-one else could shift mine out but me, as well. I guess I just give it a lil more *** since its mine and all. There is a increase/decrease screw on the side of the tranny, but I'am not so sure it is designed to aliviate the problem. I haven't read the manual on that topic yet.
Ive had some trouble switching from reverse to neutral. I found out that you have to give it a little gas while trying to switch. That works for me on both my Rubicon and my Wolverine.
