What did I do wrong?
Old Mar 10, 2003 | 11:19 PM
BADBRONCO's Avatar
Default What did I do wrong?
I put my raptor together tonight and when I tryed to start it up it would turn over a little and then the single black wire in the harness started to smoke, i t does start it I pull start it so what could be wrong?
Old Mar 10, 2003 | 11:22 PM
sixsixT's Avatar
It sounds like you don't have a good ground connection from the battery.
Old Mar 10, 2003 | 11:23 PM
yamaha4life's Avatar
in which haness??
Old Mar 10, 2003 | 11:25 PM
warrior007's Avatar
Make sure your wiring is right, I assume you had the motor out?
When hooking all the plugs back up at the back end of the tank I believe there is a white set and black set that will plug black/white and white/black
Make sure they are black/black and white/white
I aint 100% sure, but its something to check
Old Mar 10, 2003 | 11:27 PM
BADBRONCO's Avatar
The harness right by the air box its a small black wire that plugs it right where everything else plugs together
Old Mar 10, 2003 | 11:29 PM
did you put the ground back on the block?
Old Mar 10, 2003 | 11:33 PM
BADBRONCO's Avatar
ya at first I thought that was the problem so I cleaned it off and it seemed a little bettter but not good enough
Old Mar 10, 2003 | 11:35 PM
how long has your motor been down?? i had mine down for a month and
need a charger to get it started the 12/1 dosent help much either
Old Mar 11, 2003 | 12:01 PM
BADBRONCO's Avatar
I fixed this problem it was a bad ground
bmxatv10
Oct 14, 2022 06:23 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
cboler9
Sep 24, 2015 08:35 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
