Another Problem
Old Mar 11, 2003 | 11:57 AM
BADBRONCO's Avatar
Default Another Problem
I got my starter problem fixed but now I can't get my clutch adjusted right. When I have it adjusted so I can get any pull on it , it is very light, and way off from when I took it apart. Coulkd I have put something together wrong to have this problem?
thanks
Old Mar 11, 2003 | 12:09 PM
warrior007's Avatar
You could have
I would loosen the cable, take it off the arm down by the motor. Then remove the circlip holding the clutch arm at the case and take the arm off the shaft.
then turn the shaft clockwise until it wont turn anymore. There is a dot on the arm, put the arm and spring on and make sure the dot lines up with the line on the case.
Old Mar 11, 2003 | 12:15 PM
BADBRONCO's Avatar
thanks I'll give that a try
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
