Stock HP
The Warrior and the Wolverine engines have alot in common. They are practically the same except the Wolverine has a different cam and carb. According to the Yamaha web site, the Warrior has a 36mm carb, the Wolverine has a 34mm carb and the Bruin has a 33mm carb. They all have the same compression ratio and same bore x stroke. The Warrior engine is tuned for more aggresive riding and to put power to the rear tires. The Wolverine is made for more torque to turn all 4 tires.
I believe the Warrior is around 18 - 22 HP. The Wolverine and Bruin are around 15 - 20 HP. All depends on the dyno you use.
Originally posted by: maddog56
Isnt that the blaster spec?
Originally posted by: trailrider500
I remember reading somewhere it was 17hp...
