everything i should know about engine break in??
Old Mar 20, 2003 | 06:47 PM
  #21
warrior86's Avatar
Default everything i should know about engine break in??
anyone?????sorry im impatient.
O and btw, i just called my dealer and he told me he is obligated to run it by yamaha
so im already losing some time.
and on the site, its says 20 miles, but if it idles, does that count equal to miles although its not moving ..cause the engine is still runnin?
Old Mar 20, 2003 | 08:24 PM
  #22
warrior86's Avatar
o, and i forgot to add, if this way works so well, why doesnt the manufacturer reccomend it????????????????????????????????
Old Mar 20, 2003 | 09:32 PM
  #23
Ward660R's Avatar
That last post is the key! No manufacturer or major builder will tell you to break it in like this. Does that make it the wrong way.......I didn't want to find out. Better safe than sorry in my book, especialy with Yama-one ride-ha.
Old Mar 21, 2003 | 06:56 AM
  #24
warrior86's Avatar
yeah but what that article is saying is your actually being safer and have less of a chance of being sorry if you do it the other way. It says that teh traditional way it doing irreprable (sp?) damage.
Look, all i wanna do it take care of my quad the best way humanly possible. That why i spend so much time in these forums.
Does anyone have a good reason why the other way is better than the manufacturer's but the manufacturer doesnt change??? thanks
Old Mar 21, 2003 | 07:38 AM
  #25
warrior86's Avatar
yeah i read it, but it really doesnt give a good reason why the manufacturer says it the opposite way?!?!
Old Mar 21, 2003 | 03:34 PM
  #26
garyc660R's Avatar
Break in creates lots of debre....I recommend changing the oil several times during break in.....that will result in less wear due too less contaminents in the oil. Have the valves adjusted at 20hrs too and always burp it gently.
Old Mar 21, 2003 | 03:48 PM
  #27
660bigdaddy's Avatar
i agree with gary about the debrie from break in. i replaced my stock oil tank and pulled out the oil pick up screen and found medal shavings stuck to the screen. you might want to check it so the shavings start floating around and cause unnessasary wear. only about 15-20 hours on my raptor.
skinnyr6
Aug 25, 2023 02:18 AM
greg74
Sep 10, 2019 03:03 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
clsharky
Jul 13, 2015 02:07 PM
Unzzy66
Jul 11, 2015 10:01 PM
