Warrior Problem
Old Apr 10, 2003 | 08:18 PM
kuz28's Avatar
Default Warrior Problem
My moneys on the float bowl...notorious problem with warriors...especialy warriors that have been sitting. if you store a quad (4 stroke)run with the gas "shut off" to the off position until it stalls. this will use up the gas in the bowl. (or use the float drain supplied on the carb.that makes more sense...so i don't do that.) anyways if you don't. the gas evaporates, leaving a risidue behind from additives. the floats can stick if theres enough build up.
i've also heard of the floats taking on gas and sinking, with warriors.
good luck
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
