Sorry guys *dyno runs*
Old 05-17-2003, 02:02 AM
DTR's Avatar
DTR
DTR is offline
Default Sorry guys *dyno runs*
No we do not have a eddy brake.
  #72
Old 05-17-2003, 02:37 AM
RoostItUp's Avatar
DTR: Why did the other employee say he did the work?
  #73
Old 05-17-2003, 02:44 AM
14mins's Avatar
Big bubba- something about all this seems a little strange to me. It seems that everyone knew more about what was going on with your quad before you did. lol I am glad that you have picked up a lot of HP and i think the price was fair.
DTR- Why did you chose to go dnojet mains and stock needles? I have run that combo a year and half ago and did not like the results. I have dyno jet mains and mukuni jets in my first 686 and did a lot better with all mukuni carb parts. Did you try just mukinu carb parts before going the other direction on big bubbas quad. Did you play with cam timing while you were dynoing?? or just carb tuning?? Thanks
  #74
Old 05-17-2003, 02:48 AM
RoostItUp's Avatar
Mark, they used DJ needles and Makuni mains. At least thats what I was told.
  #75
Old 05-17-2003, 12:29 PM
garyc660R's Avatar
Should'nt the Raptor be dyno'd in 4th gear since it's the 1/1 gear? 5th gear is under 1/1.....OVERDRIVE.
  #76
Old 05-17-2003, 12:44 PM
sixsixT's Avatar
Without a brake to put a load on the engine using a higher gear for tuning would be better.
  #77
Old 05-17-2003, 12:51 PM
garyc660R's Avatar
Agreed....but would'nt overall power be measured lower?
  #78
Old 05-17-2003, 01:12 PM
sixsixT's Avatar
It might have a little effect on hp but on a dyno that uses only inertia to calculate output it would be very little if any. It's how fast the roller turns and how much time did it take to get it to turn that fast. Higher gearing will turn it faster but take longer, lower gearing won't turn it as fast but will get it to speed in less time. Six or half a dozen, same thing.
  #79
Old 05-17-2003, 01:16 PM
garyc660R's Avatar
Thanks for the reply.
If 4th is 1/1 and 5th is .8/1 (hypothetically)......and the dyno measures 50 horses in 4th...then 5th would measure 40..right? Anything over 1/1 is gaining power through gearing and anything under 1/1 is loosing power.
  #80
Old 05-17-2003, 01:37 PM
sixsixT's Avatar
Not on a dyno that uses only inertia for a measurement.
Example: these are just numbers for my sorry attempt at an explanation
4th= 1000 RPM roller speed and takes 2 seconds to get there= less speed, faster time=50hp
5th= 2000 RPM roller speed and takes 4 seconds to get there= more speed,longer time=50hp
Quick Reply: Sorry guys *dyno runs*
