2004 arctic cat 400 wont start
Old 07-24-2016, 01:35 PM
Kelmik's Avatar
Default 2004 arctic cat 400 wont start
Just got the 400 as a project and can't get it to start... Got a new battery for it put it in hit the start button and nothing happens. I pulled the spark plug and pulled it over with the rope and there is no spark. Need help!!
Old 07-24-2016, 09:18 PM
hydrex's Avatar
Some of the 400's had a problem with magnets coming loose from the stator. I have one with almost 4,000 miles, still ok. I think you need to at least inspect the stator and eliminate that. I believe some owners had success epoxying the magnets back in place. Download a parts manual from mymowerparts.com The AC PN for my 2002 is AC PN 3430-001. Could also be a fuse.
Old 07-27-2016, 09:28 PM
papa hogg scoot's Avatar
Like said before flywheel magnets was glued on to flywheel instesd of machined into flywheel big problem...Like said above need to check flywheel magnets and stator...
Old 07-28-2016, 07:59 AM
hydrex's Avatar
In my dyslexic confusion, I meant flywheel. I believe you can epoxy em back on, but should also test stator and cdi box. Could get expensive, or it could be a simple fix with epoxy. You need a special tool to remove the flywheel.
Old 07-31-2016, 09:03 PM
I think flywheel wont have to be removed magnets are pointing outward after case cover removed.Well on the ones I have done
Old 07-31-2016, 09:52 PM
hydrex's Avatar
You could also buy a replacement one on eBay, if you find loose magnets and don't feel lucky to do the re-epoxy. Some owners have high miles without an issue, too. Curious what you find.
Timbo2500
03-26-2016 09:41 PM
razman_07
03-13-2016 04:06 PM
depakote
05-12-2000 06:39 PM
RidE
10-12-1999 12:30 AM
Robert Venable
08-04-1999 11:36 AM
Quick Reply: 2004 arctic cat 400 wont start
