quad revving on its own when start...video included
Either the idle adjustment on the side of the carb is turned up too high, or the slack adjustment on the throttle cable next to the throttle is too tight. Rookie move to increase the idle that way. Last option is something else is holding the side from returning to the close position. You would need to disassemble the card to correct that.
Between the intake and the carb is the only vacuum leak..Id go to a local hardware store and get a oring that fits.. the filter leak only dirt in..
I have this same issue, when I start my Yamaha YFM 350 R it wouldn't sit idle at all unless the choke was on even if I was riding it and I came to a stop it would need choke to run.
so I replaced all the jets in and completely renewed the carb, now it wont even sit in idle with the choke on I need to Feather the throttle to keep it running, i tried to adjust the idle screw but it has seized so i'm going to renew that, but for now is there anyone that has any other ideas of what it could be ?
