2003 rincon grinding when put into gear repair
Old 02-11-2018, 12:06 PM
MoHillbilly's Avatar
Default 2003 rincon grinding when put into gear repair
I have a 2003 Rincon that grinds when shifting from neutral to drive and also neutral to reverse. It is not the linkage, i believe it to be an internal problem with gears and cogs. Does anybody have any exploded view of this repair? I read where a dealership will charge $1,200 for this repair. There has to be a simpler solution. Help
Old 02-12-2018, 02:15 AM
We only ever had one in for service, and it did the gear grinding. Asked the mechanic at the local Honda dealership. His reply, "they all do that, you are lucky it is a 650 so you can slow the idle down to just above stall speed, this helps. 680s are fuel injected so you can't slow them down."
Old 02-12-2018, 04:00 PM
Default Idle creep
Whenever I put it into gear at an idle it moves. I read somewhere they call that creep. It seems like that would cause it to grind.
Old 02-13-2018, 02:51 AM
As I wrote above, adjust the carburettor throttle stop. "slow the idle down to just above stall speed, this helps."
Don't know why Honda have persisted with that horrible 3 speed auto on the Rincon. The Hydraulic auto used on the 400AT and pre 2014 Rubicon was light years ahead, sadly Honda did drop that gearbox.
Old 02-13-2018, 11:11 AM
Default 2003 Rincon shifting problems Reply
Thanks Merryman, I will try to idle it down. Interesting to note, it goes into reverse much easier and sometimes without grinding than drive. From reverse, it will shift into drive if I do it fast.
Dondi M
1) Engine problems..
8
05-22-2022 02:15 AM
Dondi M
01-15-2018 03:54 PM
ChrisK1
12-03-2017 06:13 PM
cornermike
08-24-2017 01:27 AM
eman4000
08-30-2001 12:48 PM
Quick Reply: 2003 rincon grinding when put into gear repair
