2 Stroke Wont start
Old 06-13-2013, 05:16 PM
dreazoian's Avatar
Default 2 Stroke Wont start
I got a 2 stroke atv recently for 70 bucks. Its like a 50cc or something. The person i got it from said it runs but it just needs a pull starter and a wheel bearing. I brought it home, put gas in it and i tried to drill start it and it wouldnt start and also i immediately noticed it was leaking from the carburetor. I took off the air filter and noticed it was leaking from there and i took off the carb and the intake manifold was damaged so i thought that would cause the leak so i replaced it and still same problem. It has compression, good spark, correct fuel and oil mix. dont know why it doesnt start. any help will be greatly appreciated
Old 06-13-2013, 10:21 PM
LT80's Avatar
LT80 Expert
Welcome to the forums.
Take the carb back off and clean it inside. remove both jets and clean well.
Old 06-14-2013, 01:25 AM
dreazoian's Avatar
hmm i thought that may have been a good idea but just ended up boiling it in lemon juice for an hour but obviously taking it apart i could get a better clean. Ill try that
polaris scrambler00
06-20-2015 08:49 AM
bowhunter38
06-14-2015 04:38 PM
1000gade
05-27-2015 12:37 PM
PLEA$URE
8
01-31-2000 10:55 PM
hot_shoe_cv
10-13-1999 02:16 PM
Quick Reply: 2 Stroke Wont start
